So, currently, my mag mounted antenna has 2 socks wrapped around the base so it doesn't scratch the car... I am coming to understand this should not be the case? How do I keep it from leaving scratches? lol
Yeah; you can do it that way. Nice tip!102 inch whips most certainly can be mag mounted on a vehicle ..... but you'll need a 3 or 4 mag mount for it . you-ll also need 5 or 6 inches or spring or shaft under it to get it to tune properly on the cb band . using the 5 inch shaft from a Wilson trucker antenna under the 102 may get you an acceptable vswr , if not and you need more length get the 10 inch trucker shaft and cut/tune the 102 so it tunes correctly .
Tram Triple Magnet Mount
