Found a app on Google Play that is FREE, It won't stop Robo Callers from calling, but it will stop them from filling up your voicemail box, which you have to manually go in and delete.
Problem I have been having with the Robo calls, is even if I reject the call, the Robo callers still leave a message on my voicemail which I then have to call my voicemail to delete the message...Been having to do this 5 or 6 times a day, if not more! There's no option on the phone that lets you disable the voicemail or screen who can or can't leave a message,
Found a app on Google Play that basically turns off Voicemail. So now if I reject a call, or just don't answer, instead of the call going to my voicemail box, the callers phone just keeps ringing and never go's to voicemail....
The app is called "No More Voicemail" by TelTech Systems Inc. (same people who have the "Robo Killer" app.)
Free app....and, if later you want to turn voicemail back on, there's a number you just call from your cell phone that will disable the app and turn voicemail back on...If you have AT&T for example you would call ##004# from your cell phone, and then voicemail is re-activated...The app doesn't affect your Text Messaging...just voicemail.
Other carriers voicemail re-activation numbers are-
Verizon *73
T-Mobile ##004#
Sprint *730
U.S.Cellular *920
more info on "No More Voicemail"
http://www.nomorevoicemail.co/faq.html
To get the App click here:
So far, I like this app....give it 5-Stars! ****
Verizon *73
T-Mobile ##004#
Sprint *730
U.S.Cellular *920
