no receve
rf gain
it doesn't have a rf gain its a cobra 19 ultra not a utra ll or a ultra lll its just a plane cobra 19 ultra with a squelch and a volume pa and a channel 9 switch
my friend i think he keyed it up with a bad antenna and blew a diode or a final
thanks scott
take mic plug apart and check to see that all wires are in place. The radio is keying up so I highly doubt the final is bad , did you try the PA ? you can plug ex.speaker into the PA plug , if you get audio out of that ? chances are your audio chip is OK , if not ? good chance the chip is fried and needs replaced. Try a few things first and let us know . good luck
mic plug
yea i took the plug apart its all intact um i see like two bars when i key up but no audio i need to know were what the audio chip or the audio diode is located or what it looks like last time this happened it happened to a unidon grant
that i had and it was a diode and a three legged looking element looking thing
thanks Scott
    GlocknSpiel has left the room.
  • @ kingmudduck:
    So I have a cobra 138xlr and the meter dose not work... It dose not key up and signal dose not work.... It is not stuck it the meter moves freely. now wires are resoldered on both ends...So now that do I look at. Could it be a diode or a transistor?
    Greg T has joined the room.
    Greg T has left the room.
