Reply to thread
Further ideas for noise suppression
A couple things haven't really been covered, so I'll toss in my $0.02 worth.  Where is the radio picking up its DC ground?  If it's through the mounting screws, are all the mechanical connections nice and bright?  I always run a separate lead with lugs and star washers from the chassis to a good, *close* vehicle chassis ground.  And I make sure that part of the chassis has a very low DC path back to the battery's negative pole.
Some folks use the long (and frequently fused) black/negative power lead that comes with their rig (common on ham gear) to run all the way to the battery, just like the red.  This is OK as long as the wire size is actually big enough to carry the current needed for the max current needed to run the transmitter on highest power over the entire DC power path.  If the radio is 12 feet from the battery, that means it's a 24-foot loop, and can mean a significant voltage drop when transmitting.  And if there's any resistance at any of the crimp connectors, fuse holders, battery terminals, etc., you'll lose some of the.....wait for it...... noise isolation!.... that the battery would usually provide.
As for the fuel pump, fuel gauge sending unit, wiper motors, etc. :   If you can get to them easily enough, solder a .01 uF disk capacitor across their power leads as close to the units as possible.  The little motor whine from the wipers, the tick-tick, tick-tick from the sending unit, and the smaller whine from the fuel pump, will get filtered out at their sources.
Is everyone putting their antennas at the rear of the vehicles, or at least on the roof?  Hood grooves may be convenient, but the closer you put the RF receiving element of the radio to the spark/RF generating element of the car, the more of it you'll hear.
Just my thoughts.  I'm new here, but have been a two-way tech for 35 years and a ham for almost 50.
HTH
diddly dahdidah
dit   dit
-- Zygoma --
Statesville, NC:bdh:
