Noise Floor on SS3900
HomerBB
Jan 4, 2009
3,982
2,742
273
69
Rogers, Ar
I picked up a SuperStar 3900 Plus and find it to have about the noisiest receive of any radio I've owned. The white noise is terrible. I managed to bring the noise level down on my 959 while improving the receive by simple adjustments within the radio. The question here is whether anyone knows where or what I can do on this EPT360010 board to accomplish an improvement. I have found a mod that enhances receive, however, it is said to make it sensitive to the point of potentially causing harm to the receive of the unit should a loud audio signal nearby be keyed into it.
Any hope for quieting the white noise down without losing receive?
Thanks,
Homer
Looks like this:
images
Thanks,
Homer
Looks like this:
images
Hello:
I have the same radio and I did this mods to mine,works pretty good
RX Sensitivity
Change R44 100K to 39K
Change R46 39K to 100K
***Just swap both resistors***
D20 to Schottky
D21 to Schottky
Change R81/100 Ohms to 180 Ohms (DONE)
***Improves Noise Floor,Lessens Stage Gain***
Try this mods at your own risk
73 de Tecnicoloco
Hello:
RX Sensitivity
D20 to Schottky
D21 to Schottky
73 de Tecnicoloco
Thnx!
What might the risks be? Any in particular, or just the general warning issued with all mods?
I would have a good shop do a proper alignment on it first and see if that helps. Since it's a 10m Export it was probably just converted, the receive needs to be aligned for 11m use.
