To go back to the Original Posters question, can there be a way to change the gain of a 4558 Op Amp...
The response was two fold, the way it interprets the question related on an object - in this instance two one being the Radio board it's used in EPT 3600-XX series and the 4558 Op Amp - specifically the Mic Amp section.
It would not have any real clue as to which section of the 4558 chip is being used as a Mic Amp - we know by research and thru understanding of pictorial representations (schematic symbols and circuit design) being as complex and flexible as it is, the Op amp and it's functions are of two different meanings - one side of it is used as the TX / RX switch - which is one side of a dual - function device and the Mic amp is the other half.
Secondly the response was also based upon previous dialogues from it's references (to what it has access to - is not known - presumably the entire internet and any searchable text on 4558 Op Amp) - which may include this site as long as it has public access to it - versus privileged and proprietary information which it may not be able to view the subjects discussed in privately owned and fire-walled server repositories about the 4558 Op Amp.
So perhaps you would need to be more specific in the question to AI so it can then reference which pins and which side of this dual op-amp is what you're asking it to interpret.
You may need to have it look and review Pins 1, 2 and 3 and it's circuit design to see if it can be made more effective - it may also need the component designations Rxxx and Cxxx to identify the paths the AI can then research to help you sort this out.
Just so you know, many people think AI can be entertainment and a fun tool. It is a tool, but it becomes more powerful in the tooling it can provide the answers for - if you know how to ask the Right questions to get the right answers.
Many can just cut and paste a circuit design but if you redrew and submitted the one side of the op amp so it only focused on that - it may help.
