Not Bad for a Mobile
BJ radionut
6m addict
I Support WorldwideDX.com!
May 9, 2008
4,633
5,606
623
35 miles East of Indianapolis
On the way home from work today: 15 meters/21.311
7x4an...Mohamand in Algiers,Africa
Worked with my new KJ7U Screwdriver antenna and my FT-450at @ 100 watts...
He was 59...
He gave me 57!:)
First call right through the pile-up:thumbup:
Friday morning 75m on 3.865
KW7XX...Dean...60m N of Seattle,WA
W2YBP...JIM...Nr Atlantic City,NJ
I am still working on getting the bonds all done to the truck body parts...and have not even installed a matching cap yet... antenna does not like to tune on 10m or 6m yet...
Wait till I install the rest of the bonds, then it will be time for the amplifier!!!
BUT DO I NEED IT????
All the Best
BJ
HF mobile is so much fun!! Have worked a lot of DX from my mobile. Have a ICOM 706 MKIIG, and a Tarheel 100A HP screwdriver antenna.
Not familiar with your antenna, does it need the Shunt matching coil on it? That usually only effects 80 & 40 meters impedance. And it will help SWR once you get the impedance balanced between both bands. (mine is around 48 ohms on 80 & 40 and right at 50 on up) Lots of bonding helps too.
Saw a couple of nice, used ALS 500M 500watt mobile amps at the Belton Texas Hamfest this past Saturday. Almost bought one of them. Guy only wanted $495 for it and I'm fairly certain that he would have taken $400-450 for it. But, I had my eye on a certain boatanchor receiver instead! (Hallicrafters SX-100b) So, spent my money on that instead. Works and looks like new!
Have fun DX'ing mobile, 100watts and great propagation are just about all you need.
trucker
Trucker: I have had some nice set-ups over the years, but this is by far the hardest I've worked to "do-it right"
I've used HamSticks/Hustlers...etc...for years...Just throw them on a mount and go and worked all over.
I have over time learned if you want them to be really good and efficeint...You must do the work.
On 75m last Friday morning when I logged...WA/NJ...There were Mich/Ohio/FLA.... op's all in there in a group...And every op in the group was hearing my mobile...Good conditions/ Yes! But still not bad for a 100 watts!
Well off to the commute....See what today brings
You have a fine day fellow mobiler...maybe meet you "In the Air":D
All the Best
BJ
