I made this one-
http://www.w8ji.com/windom_off_center_fed.htm
137 ft. I found by watching my field strength meter that the coax was radiating so I made a Balun using a 3 litre soda bottle and wound around 21 ft of coax around it and it is totally gone ! http://www.hamuniverse.com/balun.html
I made the antenna out of clothes line . I bought 2 100ft rolls at $3.00 a roll. The speaker wire binding post was just under $3.00. So I have around $9.00 in the antenna. I use it for 80 and 40 meters and it works excellent ! My tuner tunes my aluminum groundplane for 20 meters and up . I have it going out of my attic to a tree which I tied a piece of cloth line and a big steel nut that I used to throw up in the tree branches. The ground side of the antenna is in the attic. That way the coax drops out of the attic vent down to my radio room window.
