On nice clear days could you bounce CB Signals off the moon like they do in ham radio? If you pointed a directional antenna that way?
Provided the atmosphere was in our favor that day?
In the 1970's there was a ham who worked 10 meter EME on a regular basis. He was featured in either QST or the ARRL handbook with a black and white photo of the antenna. It was a single, large parabolic dish that appeared to be about the same size as the house is stood beside.
If that is the one that used a destroyer gun mount for the steerable base it was not for 10m. In fact a dish 30 feet in diameter would not have any appreciable gain on 10m. A dish for HF even at 30 MHz would be HUGE and then some.
It's been a while since I've seen this picture but as I recall the dish was much larger than 30 feet in diameter. It was the largest dish I've ever seen on private property. Big enough that I'm just about sure it's no longer up. Although I was fairly certain it was a dish for 10 meters, it's also been long enough that my memory could be wrong.
Wouldn't the person or persons he was working also be bouncing signals off the moon? Presuming it had to be done at night. During daylight hours how would you tell the difference between eme and normal ionosphere propagation?
I think I remember reading that the ionosphere would attenuate hf signals or reflect them back to earth long before any signal would make it to space let alone make it to and bounce off the moon.
