With my Predator 10K antenna what will the coil spacing between turns as well as the overall coil length effect when altered.
I used to be R-50 X-0 but now am R-58 X-0 and am wondering if my touching up the coil spacing has affected the readings.
Hit a low branch and the coil was shoved off center, I centered it and equally spaced the distances between the coils but have no idea the overall length of the coil or effects thereto.
Just trying to track down why my ohms is off. I have new coax coming too. The change did come after my homemade ring terminal coax was used.
Both events happened around the same time, so I am not sure which is responsible.
Just trying to understand more.
Thanks
Thanks
