ok guys....i got a ton of questions
what will work as an HDTV antenna to RX the FREE "Over The Air" broadcasts???
can i build my own antenna???? if so,is a yagi type possible????
what is the range of the "OTA" broadcast???? 10mi? 20mi? 30mi?
what connectors and coaxial cable is used or perferred specs????
should the antenna be as high as possible????
should some sort of RX amp be used????
any info is appreciated
