Pair of Cobra PR 2000WX FRS w/ Detachable Antenna, SMA !!!
Wire Weasel
Senior Moment
Dec 13, 2008
3,188
845
223
Here is a pair of rare and versatile FRS/GMRS handhelds with 2 very desirable features in particular. A long while back a VERY FEW of these type radios slipped past the FCC and came with REMOVABLE antennas so you could add a higher-gain portable ant., or use with coax to create a mobile or even base station setup. These unit's antennas are on the popular screw-on SMA type.
Only a 15 channel model. Ch's 1~7 are FRS 1~7 and Ch's 8~15 and the first 7 GMRS channels. ALL channels on board are on 462mhz so it will be an easy matter to obtain or make a mobile or base antenna tuned for 462mhz only and not having to worry about covering the 467mhz portion.
2nd great feature is for battery operation they use 6 x AA batts. Most of these handhelds use 3-4 AAA's so this 6 x AA scheme will provide much longer talk time. ~ Also has DC power port for using a wall wart, power supply or a lead to a larger external battery.
Host of features:
Selectable Low Pwr: .5w / Hi Pwr 2.3 watts
All 10 Weather Channels
SCAN
Select Memory Scan
Call Beep Tone
Roger Beep
All 38 PL Privacy Tones
Ports for Dc Pwr, Charger Port for using rechargeables, Speaker Mic
Belt Clip
Accepts any Icom Style Speaker mic
All compatible accessories for this unit are still available, many or all on ebay, as Cobra is big into the FRS/GMRS market.
Both units recently tested and used. All functions 100% Both clean with a few scratches or scuffs from minimal use. Been stored inside in a drawer.
So if you use these handhelds and have been looking for a way to increase your range with them, these will do the trick by adding/using a higher-gain alternative antenna setup !!
2 units, 2 factory ducky antennas, 2 belt clips, 1 manual
$50 shipped or will trade for a good looking and working D104 TUG8, or Turner +3 (only) desk mic. Mics must not have pitted chrome or all scratched up paint jobs, be loud clean and clear and work like they should. Turner +3's Head must be completely tight on the neck with NO movement and the round TURNER label must still be on the back of the head. Be prepared to send multiple pics of your mic.
16+ iTrader positive feedbacks here
