Palomar 200 base amp
Believe what you see. Each production run will use whatever tube the factory could buy cheapest in bulk. The socket reveals which one your amplifier takes. The 8908 has an 'octal' socket with eight fat pins. The 8950 has 12 much-skinnier pins. You'll need whatever tube fits the sockets in your unit.
Reactions: Cable Guy
I contacted the guy I got it from and he said it used 6lf6 or 6kd6 tubes. He would know as he used to use it until the keying circuit went out. He then removed and sold the tubes.
  • @ Mark Malcomb:
  • @ Naysayer:
    I’m
  • @ kingmudduck:
