Click here to find out how to win free radios from Retevis!
I have the older model with the moto-455 in there.. how do you get rid of the dreaded long sideband delay?? what do you remove for am only? pictures please...cant find any pictures on what to cut or remove...
Mine looks older has palomar 225 on the bottom that's it,,,has the mrf455 in it...does your has the delay in it too?i think mine was the fist ones that came out..
I believe there’s a 33uf capacitor near the input of that amp. Cut it out to remove the delay completely or lower the value to keep the delay but shorten it.
Didn't know that about this amp. The capacitor should be part of the RF sensing keying circuit. Without a schematic it's hard to say what value the cap is or where it is located exactly in the circuit.
I remember a large cap in parallel with the relay coil. Either a 220uf or 1000uf. Can't put my hands on a diagram.
I do remember that one of the mid-1990s models would chatter the relay when this big one was simply removed. Needed a smaller cap, like 47uf to prevent AM chatter on the contacts.
Been too long. Definitely before we had digital photography here.
And clipping just one lead of that cap, to add a switch in series with the clipped lead made the delay switchable.
Good day, I have an Icom IC910H radio. I want to program a memory with split frequency tone on TX only and NO tone on RX,. Is this possible to do from the face of the radio? I don't have the interface to connect to a computer.
