Yep. Only difference is the rectifier wiring. The high-voltage version tends to have a rectangular epoxy block with four wire leads, a "full wave bridge rectifier" device. The low-voltage version has two series pairs of 3-Amp rectifier diodes, typically 1N5405 or 1N5406. We use the 1000-Volt version 1N5408. In the forty-plus years since it was built this has become the generic device of this sort. The slightly-lower voltage versions were a bit cheaper than the 1000-Volt number decades ago. Now the 1000-Volt part is just, plain cheap. If you simply copy the layout and wire-jumper setup from the one unit to the other, this should keep you out of trouble. Just make sure you sever the foil traces that the factory cut through on the low-voltage version of that center circuit board and duplicate the bare-wire jumper layout.
