I've been using this Palomar while my phantom was being repaired, I'm ready to be put the phantom back in service, but before I do so it seems like this Palomar is or has developed a problem with the fan.
Last week I noticed that the fan stopped working. The amp still keys up in both single sideband and AM, even though the fan is not running.
I tested it and both those modes with the fan not spinning. I quickly keyed it to test the operational function of the amp not wanting to overheat the it.
I gave the fan a shot of the DeoxIT and it began quickly working and has been ever since..
this evening it stopped spinning again. I shut the amp off immediately, gave it another shot of DeoxIT, and it began to spin again. It worked fine as I left the amp on for approximately 45 minutes without keying it. I noticed the fan stopped spinning again.
Can anyone tell me if I should replace this fan, or is it another issue? I have no experience with any type of cooling fan for amplifiers and don't know if the fan itself is failing, or there is another issue. Do these fans slowly fail, or do they sporadically stop, then spin, or do they just cease to work when they fail? I would like to repair it before I put it away, as it made an excellent back up while my phantom was being repaired.
Can you please advise? Thank you very much my friends, and have an excellent 2016.
