Was reading over posts here about simple amplifier biasing to otherwise AM/FM only Class C amplifiers, by adding big resistors and reverse diodes, the normal, easy, but works, way to do it. So I thought I'd contribute this, for opinions, options, upgrades and applications.
This is a crude schematic I drew up from an amplifier I had here at my shop, it's an older, but later model, Palomar Elite 450HD (NOT the FET version). It originally came with 2SC2290A's x 4. The Bias is switched on at Transmit by an extra set of contacts on the TX/RX relay, a 4PDT being used as a 3PDT with two sets of contacts tied together for the TX Output. Not sure how "well" it regulated Bias Voltage or Current, but it did work well on SSB, lots of flowers. Circuit in this case used a L7805CV (ST Micro) and a TIP31C (EKL). Schematic may contain errors, but I tried to make sure I included everything. Sorry for the crudeness, just used MS Paint quickly to make it.
