no, have not tried to swap tubes around I didn't know if it would short another tube out but the driver tube it the one that is dimmer than the rest. I did pull it out but that's as far as I got was trying to find a cheap 8950 tube to replace but if I cant find a cheap one ill just junk this thing and find another transistor amp I just mainly wanted a tube amp because I hate charging my batteries all the time and I love the oldschool look about them tube amps. do you think swapping them will make another tube go bad?
Lets slow down for a minute.
Your first tube amp?
There is lethal voltages on top of those tubes. If you get bit it will hurt and could be fatal.
With the warning put out let's discuss swapping tubes.
Turn the amplifier off, unplug it from the power source.
Let the amplifier sit for 10 to 15 minutes and let's HOPE there are bleeder resistors in the amplifier.
If I am not mistaken I think the relay has to key to supply B+ in this amplifier.
Do you know how to discharge capacitors? If not google is your friend. I won't try to explain how to do that. Google chicken stick.
Once you have verified your caps are discharged
( a voltmeter or multimeter is used for this) THEN you can remove the wire/cap/ or whatever the tubes have on top of them connecting them to the RF plate choke.
Remove the driver tube.
Read the number on the driver tube. On several occasions I have had amps in for repair that had the wrong tubes in it. 12 pins? hey this tube will fit stick it in and oh shit does not work.
Remove another tube, pick one any one. take the one that lights up bright and put it in the driver tube socket, put the dim one in the other tube socket.
Connect the B+ wire/cap or whatever it is that is used and then put the cover back on the amp.
Take a look at the fuse and see what amperage rating it is.?? Should be 10 amp or less. If it is 20 or 30 amp you may have other issues.
Once the cover is back on then make sure the power switch is in the O F F position. Plug the amp into the power source and turn it on to see what happens.
If you do not feel comfortable, if you are unsure of any of the above STOP, take the amp to a repair tech.
