Hello all
My newest project was to bring a Palomar Skipper back from the dead, I found the problems fixed it and even found a set 0f good 8950 tubes for
it. However most tube amps that i have worked on they have had large resistors with wire wrapped around going to each plate cap and or little ferrite beads. The Skipper
does not have either? Is it not a safety item to not have the resistors feeding the tube caps? If so what size do i need to use? And should i also
do i need the little ferrite beads and if so what type do i use? I did check the schematic and from the factory it does not use any of either. But if it makes them safer i would rather use them i just eed to know what to use. Thank you and look forward to hear back.
