pdf file..take off angle / gain versus height
Henry HPSD
19DX348
Dec 14, 2006
584
272
The Netherlands
cb-antennas.com
Hi guys,
I made a diagram for a guy, but thougth it was also usefull to drop here..
Its about what height would do in aspect to gain and take off angle for horizontal antennas.
All though the antenna used is a 3el F-yagi made by us, it is also more or less "true" for every other HORIZONTAL beam antenna used on 27 Mhz.
As you can see... although the gain slightly rises (due to the additional ground gain)
it is only limited from say a 6..7 meters heigth (18/21 feet)
The take off angle does drop but also shows a "less rapid" drop as soon as more heigth is added.
I hope it is of use for someone....
Kind regards,
Henry
  • HPSD 3el 1.pdf
Reactions: 3 people
    535A has left the room.
  • @ AmericanEagle575:
