I want to make a "poor mans Balun" at the feed point. Should I coil the feeds together or make separate coils?
I am not an expert but 1 will be around soon .....I want to make a "poor mans Balun" at the feed point. Should I coil the feeds together or make separate coils?
. Dave said:That will be very good..... i did find a website with a homebrew pdl2 and i was going to post you a link and ask you if their was anything else i needed to know..
But i have just spent the last 2 days looking for it and not find it...
I have found out how it works ish ....i believe by looking at photos 1 loop connect to 1 of spreader arm for one polarity and the other loop connects to another spreader arm for the other ..
What i cannot see from photos on the net is how the loops are fixed to the boom, cannot see if they are insulated from it or not..
What i think will be a VERY good ider is if you started another thread that without doubt needs to be in the sticky list. as info on this antenna is not in abundance on the net
I Think the dimension need to build one are
1 Confirm that the driving element wire is 1 wave length long
2 spacing of elements on boom
3 length of the spreader arms the loops are connected to
4 length of the loops
5 photo of the loops attached to the boom and feed points
6 details/ dimensions of the gammermatch
I dont think i have missed anything out
thanks dave
thanks dave
