I think straight. Don't know length, sorry.
:headbang can anybody tell me the length of the cap hat radials? Ive looked everywhere and came up with nothing, also if they are supposed to be straight or at a 45 deg bent down.. almoste done resurecting this thing
Thanks
73's
I got some third hand dimensions for the New SP500 in order to do an Eznec5 model, and I was told the top hat elements were .125" x 6'. I don't think you could tell a difference whether horizontal or slanted down.
014, since you haven't installed you antenna yet, I would sure appreciate it if you could give me the correct dimensions for the two wires setup for the matcher, including the individual lengths between every turn, including up to the center holes where they attach. A drawing would also help. Can you help?
Also tell me if you can which year model you have. I want to model and old one too, and see if there is any difference to note.
Good luck.
Thanksi can maybe scetch a 2d drawing, ill use centers no o.d. gimme a bit see what i can do
73's
Me too 014. The numbers you sent were far more comprehensive (your covering every dimension) than my other sources, and the numberer's were about the same, so I'll likely try my model again soon.anytime sir! need any more lemme know, it wont be going up for a bit.. got a little more work to do....
73'S
