Plate Choke opens w/ a bang while tuning 20m
Naysayer
Solder Balls
Mar 6, 2020
246
187
53
New York
Wire looks like 24-26? Reviewing my options: re-wind or get another. Uncertain what choke goes with 2 4cx300 tubes. When the attached picture is enlarged, a bulbous glob of copper is evident on each end of the wire break. Like a melted fuse.
Choke went during 200w cw tuning with 4w drive. 20M continues to be problematic. 10 working better than 20 after more adjustments to the Input inductors but it's slow going. Have a better switch with more positions. If I can squeeze a 2" small coil stock inside, I'll try that for the higher bands. I need a better inductance meter or other piece of equipment before I put more time into the input.
Antennas working great! The new mast-mount 2:1 coax switch and 400 coax made a big difference!
neil NYC
  • @ kingmudduck:
