How do you know it was 7.8 Kv? Whatever the voltage that was a mean mother of an arc flash.
i googled it and came up with a guy in the capitol city of guatemala
and it was purportedly 13 kv, on sept 22nd , 2007
thats all i can find without spending all evening on it
here's where the video probably came from to begin with
LiveLeak.com - Electrician's Electrocution Captured On Security Cam.
sorry i dont have more info
If I had to guess I would say it is much lower voltage just by the fact that the man had no high voltage gear on (arc flash protection) and it is inconceivable that the power could be on in the electrical cabinets with the doors open with that kind of voltage. Either way there was a LOT of current available.I know of a local electrician that was working on a 660 volt three phase panel.When he threw the switch to energize the equipment the panel exploded and burned him severely. He is disfigured for life. The panel could only be energized with the door closed and as a result of a fault downstream, the resulting arc flash caused the door to blow off in the explosion nearly killing him in addition to the severe burns.I have worked around DC voltages as high as 5000 volts but even with a dead short that would just go BANG!!! and scare the hell out of you with the green and purple flash as it could not supply much more than a few amps before tripping the cutouts.Low voltage (220-660) with mega-amps is a differant story.I was always much more comfortable working with a transmitter with a few thousand volts than I was working on 220 volt AC service panel.
One note:Ever notice that the power disconnect switch on most AC panels is on the right hand side? Also ever notice that 90% of the people are right handed? Where do about 90% of the people stand when throwing the switch? That's right,they stand right in front of the friggin' panel! I always make a habit of either standing to the right of the panel and use my left hand if I can throw the switch with my left hand or turn around and place the panel to my right and use my right hand. Either way I NEVER stand in front of an electrical panel when throwing the switch.Some of the safety switches at work switch 440 volt three phase and are simple lever switches that rotate. The guys thought it was weird that I stood off to the side when turning them on or off. After I explained why I do it they began to understand. They still don't do it but I do.
My buddy has been electrocuted three times.
The first two were 34.5 kv, took some skin and a finger.
The last might have not been electrocution, but burns from a 345 Kv flash over to the bucket truck he was in while it was moved in a sub-station.
The truck had fused u joints, blown tires, a hole in the cab roof, among other damage.
Lots of skin grafts and surgeries since then.
We used to work http://www.keystoneinsulatorcleaner.com/ here.
That might even be the same truck.
