Power Tweek Galaxy DX959
Full info on these radios at cbtricks.com Both first version and later Mosfet final version.
Welcome to CBTricks
Select RADIO INFORMATION, then "G" in the alphabetical list. Then GALAXY DX VERSIONS
It's all there.
Some of these radios won't take the dual-final mod as per CBTricks. Been there, done that. They will respond nicely to a Texas Star amp though.
Maybe your radio will be able to work with the dual-final MOSFET mod. The parts are relatively cheap, and if you follow the instruction carefull and check your work as you go, it should work fine.
