I just got my predator 10k with a 9" shaft. This will be mounted in a puck mount on the roof of a 2017 Ram 1500 quad cab, would the shaft length make a difference? I went with 9"to keep the weight at the bottom and less stress on mount.
Same here. I could get the 12" to tune "OK" when mounted in the middle of my suburbans roof, but not so much on the back of the roof...Finally got tired of going over to Kale's to have him re-thread my broken shafts (which made them 26" shafts) and just started using the 17"...I found that the 17" was about as short as I could go on an extended cab pick-up and still get a good match with the power on. The longer the better but like Jesse said they are more likely to break. The 10k is a fine antenna but I switched to a 6 foot skip shooter and later a 7 foot. I expected them to fail with a 16 pill but they never did.
