Hello all you wonderful guru's of the CB world
i just got my 10k yesterday and it has a 17'' shaft i got it mounted at the top of my back rack on my pickup (can post pics if you want) im having problems matching it out the best i got was a 1.5 across all 40 it was with a different stinger that i didnt care about cause i cut a damn foot and a half out of it but than i went to cut more and now the match is way above 3, so my question to you is should I ground out my back rack from the antenna bracket??? Or should I move the whole antenna dow the rack seeing as how it has a 17'' shaft and just keep the coil above my roof or would the shaft be too close to the rack???
