Been testing for a couple of weeks to get a feel for the radio before I post a video.
Some notes so far.
- Power is about what you’d expect, no surprises. Same as other newer FCC radios doesn’t swing much from a low carrier.
- Modulation was set pretty tame out of the box. Can be adjusted by user via a hidden menu and much better after adjustment. Going to do some on-air comparisons to some other radios, McKinley to get a feel for it.
- RX is what you’d expect, no surprises
- NRC is nice, possibly better than on Aires II in function. More testing needed.
- no freq expansion. No hidden software backdoor or anything via the radio as far as I can tell although I did discover some other hidden test menus. Even though I knew it was futile I also tried every jumper combo possible on the pads but this is a 40 channel radio unless we can get programming software for the EU version loaded on it.
- Build quality is nice, more solid than 980 buttons or even Grant II if I remember correctly.
- No adjustments on the board, almost identical to the EU version minus a final in the back. Might be possible to add one and couple of other missing parts for more power.
Some notes so far.
