The mod is what
@NZ8N was talking about - but one thing we all missed...
Recognize this...schematically...
The Red circled item is the "lag resistor"
The Richard has something similar...
It was a throwback to the old days - in the Grant and 148's there was a 1Meg resistor used in the Limiter circuit that helped (if that is the word) keep the Limiter from staying on all the time. But it worked In a coupling stage area that was NPN to PNP - so you really just couldn't tailor R127 to meet the needs of how Hot or Cold the limiter was...R131 is what others usually took out to affect on AM side, R127 affected both SSB and AM limiter actions.
R339 is a 1Meg, a 105 on the chip itself...that is the main one you have to change to obtain better gain and AMC action.
The problems are
D300 - you can't remove it, but NZ8N's dropping resistor - is needed right where it stands - but - you have the power flow arriving from the Stage just ahead of the Limiter - which can put a lot of current thru the part and with the shunt installed at the limiter - it can fail and you may or may not be able to talk again because the limiter got cooked at the same time. That was one of the main quirks about the repair - we have had only one return but the Boss kept us in the loop and warned us about the Q313 Solder Blob problem as he called it.
So to reduce that current - if you use the 1K - it will not hold up well - but if you use TWO of them - it will - you use the 1K (just one) at NZ8N mod spot, and place 1K over the top of the 1 Meg resistor (105 R339) just line it right up top of the 1 Meg and tack solder both sides. You don't anything else. You've brought the limiter action down and you even have some limiter action still but allows you to attain 80+ watts (as shown on MFJ meter in Smokin Joe's shop...) if the thing can really attain it.
The D300 is a fail-safe device - one-way valve - but the Q313 and EDIT (308) Q312 (Limiter) clamp so hard - its' for that reason so it (the Fail safe) doesn't engage that fail-safe mode, the radio can go into that mode if it gets too hot or shutdown - but you didn't hear this from me ok? I get yelled at otherwise...
