Prevention of theft?
ctvanover
N/A
May 22, 2005
161
7
61
Archdale, NC 27263
Is there any product or mount out there to prevent theft of an cb radio when it's mounted in a big rig? KW's are strapped down to the dash, Peterbilt's hang down from the headliner by the mounting bracket. I was just wondering if there was such a product or locking device out there that would help from getting my radio taken by some thief.
I would bypass the antenna feature of a slide mount and manually attach the cable.
I had problems with my SWR readings when using the slide mount antenna/ quick disconnect feature in the past.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
