I put a radio in our Van and it shows good SWR when the cable is all outside the vehicle but when tucked away or routed it show the SWR sky Rockit. I even put the Antenna on our Lumina and left the radio in the Van and talked on it whith no troubles. Then I put the Antenna back on the Van and they Sky Rockited once again/ There so bad that the radio squeels and stays Keyed up at times :shock: ... now I do have an Amp inline and it really wigs out with that on. The antenna is a Wilson 5000 I thought it was needing a rebuild so thats exactly what it got. I cleaned all metal serfaces and added new coax that showed it was not the problem. This same setup (2950 Texas Star 400 and Wilson 5000) Have been used in other vehicles without a lick of problems. I tried a different Amp aswell and it does the same..I tried different power sources and now Im straight off the battery and that didnt help, Where the hell is this ground Loop coming from??? This setup works fine in the house with Both Amps) I am having trouble with in the vehicle. Is this a bad chassis ground on the Van?? I was fed up and snapping at this so figured I better let it alone and should ask this question out here, WHAT THE HELL IS GOING ON :!: :!: :?: :?:
