Q-rating
  • Thread starter Thread starter 2DX727
  • Start date Start date
2
2DX727
Guest
Two questions:
1. What is "Q" (I have an idea, but would like a specific definition)?
2. And, is it possible to calculate "Q" with a formula using the known physical measurements of an antenna, or is some sort of measuring device required (like finding the SWR)?
RCI-2950/GalaxyDX99V/TS667V/LMR-240/LiveWire Coil</p>
1. Q factor is a measure to describe the "Quality" of the circuit.
2. There are a couple different ways to measure Q factor. the ARRL Antenna book uses:
Center frequency X change in reactance for a given change in frequency / 2 X Resistance at the Center frequency X the change in frequency.
The other formula I've seen is:
Center Frequency / upper cutoff frequency - lower cutoff frequency. Cutoff Frequency is defined as the frequency at which the circuit output is reduced by -3db.
So I guess the answer is that it does take some precise measurements to determine the antenna Q factor. There are computer modeling programs that can figure it out for you based on physical dimensions.
MOleculo
</p>
  • @ Geoexplorer69:
  • @ Geoexplorer69:
