Quad Magmount and 55R4
I run a quad magmount on both of or vans I have used several open coil antennas aswell as a 75 - 80 meter workman Ham stick antenna on the mounts. I use quick dissconnects and also put an adapter together for my wifes Wilson 5000 coil for the quad magmount aswell.
Ill tell you that actually you could use a tri-mag with same results I have got one of these and used it aswell. just put the tri-mag on so there are 2 magnets forward and one to the back (upsidedown trangle) that way when moving down the highway it has a stronger more stable hold.
    535A has left the room.
  • @ AmericanEagle575:
