My 949 is acting up. When it is first turned on the radio works fine, but it seems as it heats up it will not transmit. When you key the mic it crackles, almost sounds like its starting to burn. Then it will not transmit at all. My tech has looked at the radio and says he needs a copy of the pin out voltages that you can only get if your an authorized galaxy tech. (He doesnt work on galaxy's normally, I'm only his 2nd customer with a galaxy). He needs to know what the voltages are for each part inside the radio to see which are supplying the right voltage for transmit. If anyone knows what the issue might be or get tell me where to get a copy of the pin out voltages please reply.
Thanks for any help.
