So this weekend I am installing my 102 inch whip with GP riser and corona ball. Couple questions: can I use locate or retaining compound on the corona ball once I find the correct length for low SWR? And what about using locate or dielectric grease on the antenna and riser threads? Lastly, I made a tie down bracket for the whip and I was wondering if putting a small piece of heat shrink over the section of whip that will contact the tie down bracket so it won't ground out? Otherwise i will have to find a rubber grommet that has a big enough hole for the corona ball to get through.
thanx
thanx
