I have the MFJ-259b antenna analyzer that I use to check and set my swr with. So, if I have a 1.1 or an 1.2 on my meter and the R & the X shows a high number, how do I get the R and the X down to where they need to be?
Hey ctvanover, if you put your 259b in the feed line at the same exact point as your inline meter, how does the SWR compare on the two meters?
Make sure you check at the same frequency, use the same power, and that the jumper used with the inline meter is as short as possible, or if possible add the jumper length to the feed line using a barrel connector...when checking with the analyzer.
