Welcome to the forum...I also run a Jeep Wrangler and do some good wheeling!
A basic tune up of a radio shouldn't generate more heat than a stock radio. If the Cobra 29 fits, and you like the features, then go with it. BTW, F.G. BestCommunications (link at top of the forum...tell 'em you heard about it here) sells these, tuned up to do 50 watts, or you can send it in. Uniden also makes some smaller sized radios (520 series) that are pretty good, too. I wouldn't worry too much about the heat problem with a regular CB.
Most of the time, I use a 4' Firestik while off road. With a heavy spring, It doesn't whack too much. I've used a 5' off road, and it just hit tons of stuff. I have mine mounted up as high on the tub as I could get it, though. I also suggest a good noise cancelling mic...the Jeeps are noisy as hell, and nobody likes hearing all the background noise! Do you use an external speaker? I mounted one on the left roll bar right by my ear so I can hear.
And finally NO, you don't need 18' of coax. Just use however long it takes to get from the radio to the antenna. Make sure and send you radio to a reputable shop to get tuned up. Many shops around are hacks.....
And tell all your jeep buddies from other forums about our forum...we're here to help!
</p>
</p>
