Radioddity CB-500 works on 10 meter repeaters!
Ham Radio Nerd
Apr 14, 2002
9,317
1,998
283
When I received the Radioddity CB-500 from the factory for evaluation, I noticed that the band chart included frequencies on 10 meters. It also has both CTCSS tones, DCS, and an offset setting, so I was curious if I could get it to work on 10 meter repeaters. Short answer is YES, it works! Check it out:
FYI, I renamed the band "I" to "-R". That way, when you TX using repeater offset, the screen goes from "10" to "-R" (for - repeater offset). It s a great little rig for 10m FM.
