Hello, Does anyone here know how to set the bias on an ordinary 2950? The driver bias is supposed to be measured between TP3 and TP2 It is supposed to be adjusted by VR11 to 50-60mA. On my rig the driver bias current is around 270mA and VR11 has little or no effect on it.
The final bias is measured between TP1 and TP3. It is supposed to read between 100 to 120mA. Mine reads about 10mA.
I got these values from cbtricks.com Ranger RCI-2950 Service Manual I'm using these procedures because the factory manual doesn't mention bias settings in the alignment section of the manual.
The rig basically runs well, but I'm checking bias settings because I do get an occasional report of rough audio. I can't read the markings on the transistors so I don't know if they are factory originals.
Thanks for any and all help.
