Ranger SS-3900EGHP WOW!!!
Hawkeye351
Jun 27, 2021
557
453
A friend of mine wanted me to see what I could do with this one. I told him I'd try.
Issue:
No transmit whatsoever.
No receive (when I turn it on, I do hear the speaker come on).
After checking it out, I found the following:
Shorted passthrough regulator.
Shorted AF regulator.
Small cap in front of passthrough blown in half.
Trace burnt after the AF regulator.
C204 (next to driver bias VR) blown in half.
Several traces burnt in half in front of driver.
After repairing all the above, I still have no transmit signal at all. The final bias' will adjust fine up to the specs, but the driver shows zero no matter where you turn the driver bias VR.
Driver checks fine,
Finals check fine,
Pre-driver checks fine,
Diodes mounted on finals all show good,
Antenna connection is fine,
Passthrough section now working,
Driver VR tests as a 1k ohm variable,
All parts in front of driver tests fine,
I think this radio is a lost cause, lol...
Checked frequencies off of TP3, all show higher than 16.69mhz. From the looks of the bottom of the board, someone had fun with their soldering iron and razor blade.
Here are some pics of the board (trace side). What do you all think, fixable?
8v regulator & Audio section
PLL & Adder section
Passthrough section
Output section
The board hackery is fixable. But some of it looks like it would be very tedious and time consuming work.
The exploded components make me wonder if there's some more failed parts on the board just waiting to be found. Which is additional time and effort to track all those down.
So is it fixable? Yes. Is it worth the time? Eh....
Reactions: Hawkeye351
Nice looking radio too, lol...shame it's in this shape.
It's the American Spirit edition, gold trim, gold knobs and switches, American flag face.
Shame, I may just put it to the side for later.
On to the next one, Uniden Washington (8719):
Power supply upgrade to 12a, RFX95HD mounted on rear, complete alignment.
I've got a cousin to that rig, the Super Star 3900 PLUS. Gold faceplate is all pitted, and the knobs are worse. Flag emblem still looks good, though.
    Live feed at 10:00 am EDST
  • @ Bandit1:
    Hey guys I been out a while
  • @ Naysayer:
    ARRL paid ransom for their files back from s hack attack? Todays Amateur thread Reddit
