rci 2950
glad2bme1966
Oct 30, 2010
4
if some one has or could take a pic of the inside of there rig under the speaker that would be great just picked up a 2950 with orange lcd an a few wires are not in the scoket an want to check they look the same thanks in advance you can email to va3tlw@yahoo.com
Might be easier if you post up some pics and someone here could tell you wants wrong. =)
  • @ Geoexplorer69:
  • @ Geoexplorer69:
