rci 2950dx ?
gamegetter
Aug 25, 2010
1,607
328
93
Will converting the 2950dx to run on 11 meters cause it to lose the programmable repeater offset and capabilities for a CTCSS tone option? Any other problems caused by opening the 11 meter on it.
my plans are to be able to run all 3 bands, 10,11,and 12 meters with an interchangeable whip on my wilson 5k mag mount.
thanks
I guess I should read my6 manual for mine I was under the assumption that there was a seperate board needed for the tones Ive seen on Ebay but I would thing this should be capable of it from the box converting it should not take that option away if its there and usable.
RCI-2970/50 doesn't come with CTCSS, you have to install your own tone board.
I don't think they lose repeater splits with the TX unlocked?
