I'm guessing it's just another marketing ploy and they are not quiet when the radio is at idle.I'm guessing they just designed the base unit to wrap around the mobile chassis and stuff like airflow was an afterthought. But I'd be more than happy for anyone from RCI to correct me on that.
They look cool though!How effective can the dual fans be with the 3-inch-high aluminum plate blocking the path for heat to escape? There is a heat sink behind the finals and the power supply has a fan. I don't get it. The fans are always on.View attachment 70453
They're probably loud at idle because they don't have enough air to pull backed up so close to the back panel. Probably gets worse if they spool up? I don't own one so just speculation.I'm guessing it's just another marketing ploy and they are not quiet when the radio is at idle.
With the cover removed the fans aren't too bad. With the cover on, the fans are pulling a vacuum on the aluminum plate through the vent slots. Very little air movement of a sheet of a paper towel is placed at the exit area of the fans. If the aluminum plate was only 1" above the finals, the fans would be effective.They're probably loud at idle because they don't have enough air to pull backed up so close to the back panel. Probably gets worse if they spool up? I don't own one so just speculation.
