Retevis is giving away Radios for the New Year and Every Member is Eligible. Click Here to see the details!
I have one of these radios now and it has been a very good one! I keep it as a backup radio. It was given to me from a friend who used it in his work truck, a plow truck / sander for the Marquette County Road Commission, it took a beating in that service and developed a separation between the final's leads and the circuit board.... Simple fix!
Only thing I do not like is the five pin DIN mic connector. Some have changed this to the more common sleeve type. Great modulation with the stock mic but an Astatic hand mic does wonders as long as you keep it low....
Almost identical to the PC122 and a close cousin to the Cobra 146. Not worth the effort for extra channels....
Simlar version to the Uniden PC-122 / TRC-465 / Uniden Pro 810E .......they are good radios for what they are. Solid drift free SSB operations on those. (could put a few Galaxy's to shame) Will tune up nicely , a good 20 watts SSB , best to keep more so on the low side on AM and let amp take care of things if need be there.
They will take the Galaxy/Expo N kits for extra channels . The clairifier can be open for RX and TX . A good power mic (575M6 if you can get one) will go nicely on them. You can say what you will about these radios , but they are surely decent AM/SSB radios for what they are , and if SSB is your thing ? You will be in like flint.
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
