Hello,
I recently picked up a Realistic TRC-465 radio. I bought this radio with issues, but from the description, it sounded like an audio IC.
Issues:
I replaced the audio IC with a new one I had in my parts inventory, but that did not solve the problem. The heat issue is still there, and obviously someone has messed with this radio before as "HOT" has been written in permanant marker near that section of the radio.
After more investigation, I found that the 8v regulator is the component getting hot in that area. I pulled the 8v regulator to replace it, and found that it had gotten hot enough to melt through the thin plastic insulating film.
I am currently out of 8v regulators, and have no local outlet to purchase them. I have some on order, but it will be a few days before I get them. In the meantime, I tried injecting +8v to the spot on the board where it belongs. I am still not getting audio or modulation and the PA function still will not work.
I have wired a microphone standard realistic 5 pin Din... Most websites I've seen do not have a listing for the microphone wiring for a TRC-465, and I no longer have the books that I used to have when I used to work on radios for a living.
Can anyone confirm that the Realistic TRC-465 microphone is wired standard:
If that is the correct wiring for this radio, then I will know for sure that the microphone is wired correctly.
If anyone can offer some advice, it would be greatly appreciated. This radio only seems to have problems in the audio section as Transmit & receive are right on to specs.
Issues:
- Receive but no audio output
- Transmit but no Modulation
- No PA Function
- Radio is getting hot near Audio IC / L7808 8v Regulator
- Shield / Common
- No Connection
- TX
- Audio
- RX
