K
KD5VHF
Guest
I'll let the antenna "gurus" answer the tech part but wanted to comment on the swr thing. Remember that just because the swr reading is good dosent mean the antenna will work very well. A dummy load has GREAT swr readings and although you can talk on it you won't be talking far.<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=""> Some VHF antennas can show a good swr reading on the UHF freq.s but the pattern is straight up. That might be fine to talk to a plane as they pass over but not much good for anything else. Not sure how the pattern will be the other way around but I'm guessing the results would be about the same. Heck, try it....it might just do what you need it to.
<hr />73, Mike </p>
<hr />73, Mike </p>
