I'm a newbie at cb-radio and am expirimenting and trying to understand the technical aspects, but I have a problem with the antenne.
Because I had silly SWR readings I found that I had a cable breach close to the antenne. Sometimes the antenne did work but most times it didn't. I cut off about 2 inches of the cable and re-soldered it in de foot of the antenne. To do this I had to peel of the thin black protectionstuff what was at the bottom of the mag. When I finished the repairs I put aluminium tape on the bottom of the mag.
The problem is that I get very poor SWR readings now (but they are constant now!). With the antenna of a friend which is exactly the same as mine I got good SWR readings. I was wondering, should I have used an insulator for the bottom of mag?? If yes what is the technical explination for that?? Do I need a new antenna?
I want to use the cb-radio to stay in contact with other cars when we are travelling with friends, so I don't need many miles of range, just a mile or two will do.
thanks,
Yogi.
thanks,
Yogi.
