The Retevis Holidays giveaway winner has been selected! Check Here to see who won!
It's not a transistor, it's a SCR, or silicon controlled rectifier. Turns on like a transistor, but stays turned on after the input is removed. Only turns off when you remove the power. In the Cobra 2000 it's wired in parallel with the power button. Pushing the power button to "On" shorts across the SCR effectively shutting it off.
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
