well, this can be a start of a too big adventure but lets try. I have a Galaxy Saturn for decades now and after a few years I fired it up again just to see some problems from the very start I started the TX. The first days I only did some RX listening.
I am almost sure it was good when I putt in away a few years agf course its an old transceiver and everything can go wrong inside.
To be honest I am not the biggest electronic expert but I did some things through the years and have some experience. So everything involved I did hear about and I can do solder actions. I have all the diagrams and component names of the board.
The symptom is weird.
- Lost power on FM/AM but its very different per band. The A band does 2 watt, B,C,D,E does zero watt and the F band does 6 watt
- No modulation on AM/FM/SSB! So I cant test SS wattage, only the roger beep does swing out some power but nothing through the mic. I tested 2 mics that I know are good.
I know this sounds as if where do we start but I did try to make a start.
- TR 45 had 3 black legs so I de-soldered that one and did a measure. It is a 2sc2538 and it was still good. I replaced it with a 2sc1973 and the issue is still there of course.
I de-soldered the 2 finals and they are both good when I measure them. I didn't tested the 2166 yet.
Is there anyone that can try to shine some light on this? Do I have 2 separated issues or is there a possibility that the audio and power loss are the same component(s)
I know there are some measure point like tp 7,8,9 if I am correct, but I have no experience with those measure tecnics so when I have to do this through those points I need some help in what to use and how to use.
Any option is good, I need to find a new entree to start this adventure
