RF Gain Pot no longer working on President Richard CB
littletunny
New Member
Nov 25, 2022
Per the thread title, I have a recently purchased President Richard and the RF gain stays wide open and does not change when turning. I guess i would rather have it break on max gain than the other way around but it is still annoying. I pulled the potentiometer and measured resistance and it is providing resistance. I guess i need to look further up the board. Any tips?? Thanks!!
If you're referring to the current Richard, send that dude in on warranty.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
